Pimping up my Tudor !
magicman
Post by magicman »
Sorry, Bit of an overstatement to draw in potential, helpers.
In summary, I love my BB58 on the bracelet, but I've got a wrist size, that means I seem to fall in-between sizes.
With no half links currently available I've tried the 2 standard options.
Remove a link and fit to hole 3 on the clasp it's too tight.
Add a link and fit to hole 1 too loose.
So I'm after suggestions.
I've left it with the extra link on, so it's a bit loose, then I cut up a silicone heel pad and stuck in to the inside of the clasp.
It's actually done the job quote nicely.
Just wondering if anyone can think of a purpose made product, that I could use, to form the clasp pad.
I've been on Amazon, most silicone/Gel Pads are too thick and the silicone tapes are too thin.
I think 1-2 mm thick, self adhesive, silicone or rubber. In a cutable sheet or in rectangle pads, would do the job.
Any suggestions are appreciated.
Not the neatest, but it's just a prototype.
Regards Steve
missF
CW Forum Poet Laureate
Re: Pimping up my Tudor !
Post by missF »
Is adhesive neoprene any use? Maybe too squishy? This stuff's 1mm, but I'm sure you could get thicker:
https://www.amazon.co.uk/BENECREAT-Adhe ... 83&sr=8-11
'The only reason for time is so that everything doesn't happen at once'........Albert Einstein
You could go pump some iron, Steve. Then the loose setting would be a better fit. :D
Linguistic sophist; (nearly ex-) teacher; pilgrim; wannabe travel writer
Walk a while in others' shoes...
magicman
Post by magicman »
Thanks missF, I've ordered some foot pads but the neoprene may work, better as it's probably more squishy.
AVO, I've really got about 2 stones of fat to lose first, so I might be removing links, in future.
I let you know how I get on with this, but keep the suggestions coming.
I'd have thought the jewelry trade would have a more purpose made option.
Regards Steve
jkbarnes
Post by jkbarnes »
While I don’t have any suggestions, I do think your solution is quite ingenious! If it works, problem solved.
Andrew
C65 Trident Vintage
C65 AM GT LE
brash47
Post by brash47 »
Try this on for size and don't worry about how to fix the current bracelet.
https://www.strapcode.com/collections/f ... ifty-eight
If you don't like the clasp, you can always purchase a separate clasp from them in the size 16mm.
CW-watches: 25
I remember a couple of years ago @richtel having the same issue with a watch and making a shim that he attached to the caseback, to solve the issue.
C8 Reg LE| C8 M2.04 LE| C8 Al Deere| C9 FLE| C9 Me109 SPC LE| C11 Mak Navy| C40
C60 FLEx2| C60 Bronze-316L| C60 Apex-Elite P'type-AbyssSH21-Chrono |C65 Chrono-AM GT 2VEV
Bident
Post by Bident »
Not sure this works for everyone, but sometimes I've found moving a link from one side to the other and/or reversing the bracelet so the clasp opens the other way improves the fit when the bracelet is otherwise between sizing positions on the microadjust.
magicman
Post by magicman »
brash47 wrote: Fri Mar 19, 2021 5:23 pm Try this on for size and don't worry about how to fix the current bracelet.
They look decent, but I'm not in a position to spend that type of money on a replacement bracelet.
Maybe they can produce half links in future.
Regards Steve
magicman
Post by magicman »
Bident wrote: Sat Mar 20, 2021 1:56 am Not sure this works for everyone, but sometimes I've found moving a link from one side to the other and/or reversing the bracelet so the clasp opens the other way improves the fit when the bracelet is otherwise between sizing positions on the microadjust.
I did the first part, and that's how it is currently, with the clasp, nice and central.
Putting the clasp around the other way, is not for me.
Regards Steve
Bident
Post by Bident »
magicman wrote: Sat Mar 20, 2021 11:02 am
Regards Steve
:lol: I felt the same way at first, but after I tried it once, I became a convert. I only do it for a few watches/bracelets, including my CW bracelets, where the links are on the longer side and no half links are included.
magicman
Post by magicman »
Bident wrote: Sat Mar 20, 2021 3:37 pm
Regards Steve
You'll be wearing the face on the inside next !
Regards Steve
Bident
Post by Bident »
magicman wrote: Sat Mar 20, 2021 3:41 pm
Regards Steve
Regards Steve
I do like that Trident stamped caseback..... 🤔
magicman
Post by magicman »
Not much going on, on the back of the Tudor.
Regards Steve
Bungle-ator
Post by Bungle-ator »
I think I'd ditch the bracelet and put a snazzy strap on it for a bit. If you notice your wrist size change you can always stick it back on.
