As someone who's useless with hammers, nails, pliers, and ANYTHING delicate I know I'm gonna need to ask for experienced advice.
So here goes...
Are the pins and collars used on CW bracelets unique, and only available via Customer Services, or generic?
I'm sure that although my bracelets (6 in total so far) are fitting fine now I've mangled some pins and collars during the customisations. So if further adjustments are ever need more pins and collars would be needed. Considering the range covers Mk2 and Mk3 C60 bracelets, plus C65's are they common parts or CW specific?
It must be a common issue but what are your recommended solutions?
CW pins and collars for bracelets
- alanrolfe01
- CW-watches: 25
Re: CW pins and collars for bracelets
They aren't generic. Most tube lengths are different to fit inside one of the sections of a bracelet link. The pins are different lengths. The tube and pin diameters are different, or appropriate to each other to give a tight, but not impossible fit.
CW may use standard diameters pins and collars for all bracelets, but the lengths will not be the same.
A slightly different thing, but a 3 section link will have the collar in the centre section of the link. (The diameter of the hole will be slightly larger to accommodate and retain the collar within the section). A five section link will have the collar in either the second or fourth section of the link. The arrow on a bracelet should indicate where the collar is so the pin can be pushed out. I think I may have without thinking installed collars in the incorrect section of a five section bracelet link giving me the future problem of not being able to push it out again, without a lot of difficulty. (eg - needing a much longer pin pusher than I have). At the time, I was probably happy to just get the thing re-assembled, and didn't realize the significance of the arrow. I am not sure I have done this, but it's a definite maybe.
If you search recent posts by Rich, @richtel, I think you will find a post with details of the measurements for CW pins and collars.
Remember the centre links are different widths between the old, PCL, bracelets and the current all brushed ones.
- 355 Views
- 306 Views
