Scuffed Strap
Scuffed Strap
I noticed that the end of one my cordovan straps has become slightly scuffed. I think the holes in the lug must be slightly too close to the watch case (not CW) so the strap rubs against the case, and it's slight grazed the surface of the leather. I have got a new strap with curved ends coming. The other part of the strap seems to be ok. The abrasion is hardly noticeable but I know it's there, and I wondered if I could repair this slight scuff. Any thoughts?
It's hard to photo, but here's a pic.
Re: Scuffed Strap
Clear shoe polish?
CW-watches: 34
Re: Scuffed Strap
Leather Conditioner? i.e. Gliptone.
iain
Re: Scuffed Strap
Post by iain »
Had this with quite a few straps over the years. I use shoe polish and it covers it up, however it won’t prevent the issue that caused it from doing it again. You could also remove the spring bars and fit curved ones, I find that usually helps.
exHowfener
Re: Scuffed Strap
Post by exHowfener »
If you're going down the shoe polish route (I would too), then Saphir do a dedicated cordovan leather polish. Not the cheapest, but top quality stuff across the range.
Re: Scuffed Strap
Thanks for the suggestions. I have a curved end strap on the way, and I'll be careful about making sure there's clearance in future. I don't want to try to force a curve into the strap end. I'll have a look at the cordovan polish idea.
(I have had a look at saphir, and noted about a recommendation not to use polish with turps, so thanks for that tip especially)
Re: Scuffed Strap
Post by TigerChris »
Every straight end strap I’ve had on my MB2 has scuffs like that due to the knurled barrel - I couldn’t give a monkeys, it shows it’s mine and adds character to the strap. I don’t think I have a single leather strap without some sort of scuff or mark on it - if I don’t scuff them my dogs claws when play fighting certainly do :lol:
I do use a leather conditioner/cleaner on my straps, which gets rid of most scuffs anyway, but that’s because I don’t buy into the ‘can’t get leather straps wet’ theory - you go out in the rain in leather shoes/boots don’t you? So, I clean and condition my straps the same as I do a pair of boots and the water beads off them nicely. Chamberlains leather milk, top stuff.
couryj
Re: Scuffed Strap
Post by couryj »
A good leather cleaner and conditioner will fix this right up. I've used Lexol for years but now prefer products from shine supply; it's good stuff.
