Hairline clasp marks
Anyone got any tips for polishing these out and what products to use?
Steinhart Ocean 39 vintage red/blue ceramic,Olko edition
C65 Super comp
C60 Trident Pro
C60 Blue LE
Omega Seamaster 300m
Longines Admiral Chronograph
C65 Super comp
C60 Trident Pro
C60 Blue LE
Re: Hairline clasp marks
Depends on the finish of the clasp. Polished use Cape Cod or, if brushed, something like this Refinishing Pad.
https://www.watchobsession.co.uk/collec ... ishing-pad
Otherwise, very fine Emery Cloth. I have a small piece that is ages old and well used, such that it works by brushing and polishing at the same time.
Looks brushed to me,C60 mk1 tridentBahnstormer_vRS wrote: ↑Tue Mar 02, 2021 10:38 am Depends on the finish of the clasp. Polished use Cape Cod or, if brushed, something like this Refinishing Pad.
Last edited by Bahnstormer_vRS on Tue Mar 02, 2021 3:54 pm, edited 1 time in total.
Reason: Attached photo 'Placed in Line' - https://www.christopherwardforum.com/viewtopic.php?f=4&t=55242
C65 Super comp
C60 Trident Pro
C60 Blue LE
C65 Super comp
C60 Trident Pro
C60 Blue LE
- Thermexman
Don't use Cape Cod on that unless you want it super shiny! If the hairline scratches bother you on that, you'll have to take the risk of using a fine scourer. It's a job that requires a little patience and practice? It's just a matter of very lightly brushing in the direction of the grain, as it were. Very easy to mess it up though.....!
Cheers just want it as is,brushed finishThermexman wrote: ↑Tue Mar 02, 2021 1:33 pm Don't use Cape Cod on that unless you want it super shiny!
C65 Super comp
C60 Trident Pro
C60 Blue LE
C65 Super comp
C60 Trident Pro
C60 Blue LE
- Thermexman
Exactly my advice too.Thermexman wrote: ↑Tue Mar 02, 2021 1:33 pm Don't use Cape Cod on that unless you want it super shiny! If the hairline scratches bother you on that, you'll have to take the risk of using a fine scourer. It's a job that requires a little patience and practice? It's just a matter of very lightly brushing in the direction of the grain, as it were. Very easy to mess it up though.....!
Go really easy and gentle when brushing. You can always go a little harder if need be, but its a real pain to try and smooth out brush work that is too deep because you pressed too hard.
Good luck.
My Speedy's clasp is full of swirlies. Battle scars. I just wear it.
- Paul Drawmer
ink rubber. (eraser) for those over the water.
I'll try the eraser technique, if that don't work on reflection,it's something I can live with,judging on how ultimately I could end ruining the finish.
C65 Super comp
C60 Trident Pro
C60 Blue LE
C65 Super comp
C60 Trident Pro
C60 Blue LE
- magicman
I use my wife's nail polishing pads. They are like superfine Emery and the buffer is similar feel to an Eraser.
Regards Steve
Here's a clasp that had minor scuffs, just took the larger scuffs out, but a finer finish can be achieved, with more time.
Regards Steve
Selling Tudor Pelagos 39
It’s much easier to get it right if you put the green pad on a surface and brush the clasp firmly and slowly against the pad in the direction of the original brushing. You have way more control than trying to hold the clasp firmly while you brush it with the green pad. Be gentle at first, and if it’s not having the desired effect, increase the pressure gradually.Thermexman wrote: ↑Tue Mar 02, 2021 1:33 pm Don't use Cape Cod on that unless you want it super shiny! If the hairline scratches bother you on that, you'll have to take the risk of using a fine scourer. It's a job that requires a little patience and practice? It's just a matter of very lightly brushing in the direction of the grain, as it were. Very easy to mess it up though.....!
Just call me Diderot
- Thermexman
^^^Good advice.0uatiOW wrote: ↑Thu Mar 04, 2021 1:04 amIt’s much easier to get it right if you put the green pad on a surface and brush the clasp firmly and slowly against the pad in the direction of the original brushing. You have way more control than trying to hold the clasp firmly while you brush it with the green pad. Be gentle at first, and if it’s not having the desired effect, increase the pressure gradually.Thermexman wrote: ↑Tue Mar 02, 2021 1:33 pm Don't use Cape Cod on that unless you want it super shiny! If the hairline scratches bother you on that, you'll have to take the risk of using a fine scourer. It's a job that requires a little patience and practice? It's just a matter of very lightly brushing in the direction of the grain, as it were. Very easy to mess it up though.....!
- 768 Views
Last post by DirkWatch
- 265 Views
Last post by iain
- 207 Views
Last post by The Watcher CW
- 157 Views
