Deployant/strap update
A simple swap of the deployants I got from StrapMeister has made them both usable! I’m very happy with the end results.
Re: Deployant/strap update
Leon O, I’ve swapped the the deployant clasps. Now both the Horween strap from Barton and my tropic rubber strat from Moose Strap Co. both have deployants. Very happy with both.
Thanks for posting this Andrew.
I wanted one (or a few) of WatchGecko's new tropic straps, but they're too long for my wrist.
Had the same idea about using a Bader/Omega style deployant so the longer length runs inside, so good to see it in action.
I recall seeing a deployant that also had a metal piece filling the gap where the middle part of the buckle usually sits.
My 'Googling' skills are really being put to the test trying to find it again.
That's a great result Andrew
They both appear to work well and, with the Horween strap, it means that you don't need to cut the keeper off.
I was going to ask you about that! I bought a deployant from WatchGecko for a leather strap for my 1675. It is the kind that allows for the tail to still be routed through the keepers. Looks cleaner IMO. I have also found that reversing the pieces so the tail is at 12 and the buckle is at 6 (Seiko style) helps when putting it on. Really like the look on the C65.
I hear what you’re saying about a cleaner look. I initially had the clasp from the tropic on the C65 because I thought the excess strap being routed under would look cleaner (and it’s the higher quality clasp). But it didn’t look cleaner because of the permanently attached strap keeper!rkovars wrote: ↑Fri Feb 12, 2021 3:53 pm I was going to ask you about that! I bought a deployant from WatchGecko for a leather strap for my 1675. It is the kind that allows for the tail to still be routed through the keepers. Looks cleaner IMO. I have also found that reversing the pieces so the tail is at 12 and the buckle is at 6 (Seiko style) helps when putting it on. Really like the look on the C65.
Swapping clasps between the straps/watches clearly makes for a cleaner look on both now...and makes them both usable. I’m a very happy camper.
Ryan I ended up getting one of those tropics in the sale. From the measurements I knew that the strap would be longer than ideal for my 7” wrist, but thought it worth a punt at the further reduced sale price, plus used the WATCHGECKO10 code for an additional discount.StrappedUp wrote: ↑Fri Feb 12, 2021 9:57 am Thanks for posting this Andrew.
Yep longer than ideal, other than for those that like a long tail on a strap.
However I have sorted the problem! Much better know. I went for a simple diagonal cut, to give a similar end to an isofrane.
Sort of ok.
Although I cut from the underside, rather than top down and can see that I need to tidy the line slightly.
Probably would have been better to have been a bit more patient and used a Stanley knife. Rather than think “I am going to trim it now”, whilst cooking. Taking off the watch and picking up the nearest kitchen knife, probably not the best idea!
I may give one a go while they're on sale then.
Is that a 22mm for your SC?
With the ISOfrane, is there any utility to the angled end of the strap, or is it purely cosmetic?
I don’t really know Andrew. My guess - purely cosmetic.
Sure is. I will take a pic and put it up in CW of the day. A tight fit at the lugs.StrappedUp wrote: ↑Sat Feb 13, 2021 12:19 am I may give one a go while they're on sale then.
You aren’t thinking of the IWC deployant are you? These have the piece you describe but don’t fit like the Bader style deployant. Even without the piece, the tail of the strap would hide the gap, but it’s typical of IWCs attention to detail to include it anyway.StrappedUp wrote: ↑Fri Feb 12, 2021 9:57 am I recall seeing a deployant that also had a metal piece filling the gap where the middle part of the buckle usually sits.
I may have been Iain. I did see these during my searches, but discounted them on the basis that the longer part sits on top like a regular strap.
Obviously the Omegas, Tags etc are meant to be used with OEM straps and therefore have no need for that 'aesthetic' piece.
There's a gap for an aftermarket bader-style buckle with it though.
I will update if I come across what I thought I saw
