Adjusting a screw in bracelet
- missF
- CW Forum Poet Laureate
My Elliot Brown Kimmeridge has arrived! It's lovely. Pics later once I can adjust the bracelet.....
The watch comes with a jeweller's screwdriver for adjusting the bracelet, but try as I might I can't get the screw to budge, and I'm risking stripping the screw head. It says in the booklet that the screws have some kind of thread locking compound on them. So my question is = is there a way of getting rid of this compound so I can safely unscrew the screws??
Thanks!
Thanks!
Watchaholic
‘Imprudently spendy’
Thomcat00
Watchaholic
Thomcat00
Re: Adjusting a screw in bracelet
Soak the bracelet in hot tap water for about 5 minutes. That will usually soften the thread lock enough to allow removal. Possible you may have to repeat a couple times.
- missF
Thanks Kip!
Watchaholic
Thomcat00
Watchaholic
Thomcat00
Don't use Christmas cracker screwdrivers. They're not perfect for watches. Apparently.
- missF
Watchaholic
Thomcat00
Watchaholic
Thomcat00
- missF
Wrestling with a spring bar now.
I have (a) shaky hands and (b) no patience!
Watchaholic
Thomcat00
Watchaholic
Thomcat00
I bought a Davidoff watch that had this problem. I got a jeweller to remove all the screws which were all threadlocked. (I actually used an excellent watch strap seller on my local market). Coincidentally, I also saw a Jennie Elle video about an omega this week with the same issue, and she had to use a jeweller as well.
I would get a jeweller to undo all your screws once and for all. It's especially hard if your bracelet has screws on both sides, as you need two screwdrivers, a special tool, and a third hand!
Good luck.
Here's a picture of the screws and links that didn't go back in with my watch It's hard to see but there's a lot of whitish compound still in the screw grooves. The screws still work fine. My focus is very slightly off/slight camera shake.
Good luck.
- missF
^^ thanks for that good advice
I found with the screw in bars that one of them was just impossible, but I managed to unscrew the adjacent ones. I got the size adjusted, I'm now back with a regular spring bar where there's a half link adjust at the clasp. It's proving intransigent.....
Watchaholic
Thomcat00
Watchaholic
Thomcat00
Well as long as you obey the social distancing requirements down your way and you don't go beyond your bubble..... but wash your hands and don't sneeze on it!
I didn't think you could be old enough so maybe you're just boasting now
Did you manage to break through the thread locking solution?
Is yours the type of watch which has screw heads at both sides of the links and yet the manufacturer supplies one driver when what you need is two?
- missF
Success! Almost......
There is only a screw head on one side of the bracelet - my shaky hands definitely couldn't cope with a screwdriver on each side....
I got through the thread locking solution on all but one of the screws.
I also adjusted the half link adjustment on one side of the clasp.
I now find I need the half link adjustment on the other side to make it fit better.....
What I really need is somewhere I can write all this down and vent while I go..... (Oh... )
Watchaholic
Thomcat00
Watchaholic
Thomcat00
- missF
Watchaholic
Thomcat00
Watchaholic
Thomcat00
Yay! You did it Lindsey.
Top notch and a top notch choice of watch. Wear it in good health.
Bravo, well done Lindsey.
Nowt like chucking yourself in at the deep end, getting stuck and then overcoming the adversity!!!
A great ticky companion to support you in the new year.....
Wishing you strength, calmness and happiness on the new year!!
Sent from my Redmi Note 9 Pro using Tapatalk
Well done Lindsey. I hope your screwdrivers survived. It's the sort of thing that makes you appreciate a Bergeon despite the price. I have a 1.6mm Bergeon which has given me great service, unlike some less expensive ones.
Why on earth do people think they need loctite on bracelet screws. And why doesn't everyone make quick release bracelets and straps.
Now, for your next experience in frustration, try sizing a bracelet with pins and collars. CW with these, to the dark side they went.
- missF
Thanks for the good wishes smegs, it's good to hear from you again - you've been missedsmegwina wrote: ↑Thu Dec 31, 2020 8:31 pm Bravo, well done Lindsey.
Wishing you peace and good wishes for the New Year
Watchaholic
Thomcat00
Watchaholic
Thomcat00
- 330 Views
Last post by Chris GB
- 19 Replies
- 1104 Views
Last post by RichM
- 15 Replies
- 669 Views
Last post by exHowfener
- 461 Views
Last post by SammyD
