Due to the differences in the redesigned case of the Original Trident Pro (MKI) and the Trident Pro 600 (MKII) here is a list of codes for straps that will/will not fit each model.
The bracelets (22-SXS-C60)(C60SXS3)(22-SXS-C65 )(22-STL-60-KXK-MA) (22-STL-65-SXS-MK2-MA)(22-TIT-60-KTXKT-MA) (22-TIT-60-TXT-MA) will fit the 42mm C60 MKI or 43mm C60 MKII.
The bracelets (20-STL-60-SXS-MA) (20-STL-60-KXK-MA) (20-STL-65-SXS-MA) will fit the C61 38mm Trident Pro or the the C60 Trident 38mm MKII.
The C60 MKI bracelet (C60SXS3) does not does not fit the C60 MKII. This is because the MKI bracelet has a deeper shelf on the shoulder piece.
The MKI straps that will not fit the MKII are coded......
42mm
C60SXK
C60SXT
C60SXO
C60SXKO
C60SXSi3
38mm
20-SXK-C61
20-SXT-C61
20-SXO-C61
20-SXKO-C61
These straps have a hard insert in the end of the strap that prevents proper fit with the MKII case.
Any of the new 20mm straps that are coded with a C65 will fit the C61 or C60-38.
20-SXX-C65-XX These have a curved end and use a curved spring bar.
These will also fit the C61(W61) or C60-38.
20-SXX-C5-XX These will fit but have a straight end.
20-SXX-C8-XX These will fit but have a straight end.
C60 Trident strap guide
- 108 Views
Last post by SteveMIZ0104
- 368 Views
Last post by CodyAWWC
- 435 Views
- 40 Views
Last post by zgrabill
- 355 Views
