Crown In or Out - Quartz
- TheBeatles
What is the Forum consensus on leaving crown in/out on quartz watches?
I leave mine in, so they are pick up and go. I figure a battery change every 3/4/5 years depending on watch/battery etc is not that much of an inconvenience.
Also, is there a possibility of leakage if left out due to lack of usage?
Reason I’m asking is - my wife just checked some of her watches with crown out. She hasn’t worn them for a couple of years. Batteries were dead anyway. Perhaps a poor quality battery!
I’ve just spent the morning changing them over with instructions to leave crown in and we’ll see.
Basically, I'm for anything that gets you through the night. Be it prayer, tranquilizers or a bottle of Jack Daniels, Frank Sinatra
All You Need Is Love, The Beatles
Too much of anything is bad. But too much of good whiskey is barely enough, Mark Twain
- TheBeatles
Re: Crown In or Out - Quartz
This all started after I mentioned Ferg changing battery on his C3 (Thanks, Ferg)
Plus I spoke to a friend over the weekend who has the crown on his Bulova MoonWatch pulled out. Mine has always been in and only had first battery change last December after 4 yrs 7 months from purchase.
I agree - leave the crowns in operating position, it doesn't make much difference to battery lifetime as the battery will self discharge anyway and they are less likely to leak under load, while a quick glance at the dial shows that the battery is discharged which is when leakage is more probable. In truth though, to prevent leak damage the only sure way is to store without batteries.
- TigerChris
I don’t pull the crown on quartz, what’s the point? If you have to set it every time you pick it up you may aswell just ditch the quartz and stick to auto/hand wind. Let’s not forget that the majority of ‘normal’ people wear quartz watches and I can’t see anyone pulling the crown to save battery and have to mess about resetting. Seems stupid to me
In – always. Helps to protect against ingress of moisture, dust and foreign objects.
- Kansas City Milkman
- CW-watches: 14
I keep the crown in on my Quartz watches and think I go 3 to 4 years between battery changes
The crown isn't an on/off switch in a quartz in most movements. It disengages the stepper motor from the hands so that they can be set. The rest is still running. In some cases a brake is applies to the movement. So pulling the crown does little for battery life. I leave the crowns in to be sure that they are dust and water tight (even low water resistance watches this will help).
That’s what I was thinking. I know I’ve seen some quartz movements that specifically mention a low power mode when the crown is pulled it, but assumed that was unique to those movements.rkovars wrote: ↑Tue Jul 06, 2021 5:48 pm The crown isn't an on/off switch in a quartz in most movements. It disengages the stepper motor from the hands so that they can be set. The rest is still running. In some cases a brake is applies to the movement. So pulling the crown does little for battery life. I leave the crowns in to be sure that they are dust and water tight (even low water resistance watches this will help).
Yep. There are a few out there to be sure. I've never owned one but even then I think I would still leave it running.jkbarnes wrote: ↑Tue Jul 06, 2021 7:09 pmThat’s what I was thinking. I know I’ve seen some quartz movements that specifically mention a low power mode when the crown is pulled it, but assumed that was unique to those movements.rkovars wrote: ↑Tue Jul 06, 2021 5:48 pm The crown isn't an on/off switch in a quartz in most movements. It disengages the stepper motor from the hands so that they can be set. The rest is still running. In some cases a brake is applies to the movement. So pulling the crown does little for battery life. I leave the crowns in to be sure that they are dust and water tight (even low water resistance watches this will help).
Crown in and leave it ticking, for me.
As mentioned, it keeps the insides clean.
I tend to keep the the crown in but on my Longines VHP the manuals on both watches say that you should have the crown out for them to go into ‘standby’ mode to preserve battery life.
Treyford
I don’t own any quartz watches but if I did crown in always, isn’t that the whole point of a quartz?? To have it running and time set whenever you go to wear it??
I may be off base here but with these watches/movements isn't more like a 'low power' mode meaning that when it is pushed in it sets the hands at the correct time automatically? That would be ideal. I would assume there are also extra measures taken to make sure gaskets are in place when the crown is pulled.
I think I would still probably keep them running unless I knew I would be away from a service center for an extended period like a military deployment or something of that nature.
- TheBeatles
Regarding “stand by” mode mentioned.
I’ve just checked manual for my Bulova Moon Watch, which states
“Note: When the crown is in the “OUT” position, the motor and hands stop. Only the quartz crystal continues to vibrate, using very little power. If the watch is to be stored for a length of time, it is recommended that the crown be left in the “OUT” position to prolong battery life.”
I’m still happier to leave in. Especially as a battery change is only every 4/5 years.
- Thegreyman
The grab and go convenience of quartz is nullified by leaving the crown out, the battery saving if any doesn’t seem to justify doing this either.
- 35 Replies
- 1963 Views
Last post by Leon O
- 181 Views
Last post by abeardsley2020
- 19 Replies
- 1106 Views
Last post by RichM
- 206 Views
