So today, I visited my local market, to get a battery changed. I just hadn't been able to shift the case back at all - I watched the expert, and he had a tool similar to a case press, that unscrewed the case back, rather than a Jaxa. He obviously put it back on tight as well, as I still can't shift it. I intended to use this watch when @MissF suggested we wore inexpensive watches for a while - but I couldn't as it wasn't running. So it's running now. It's also now on a CW camel strap, which goes very well, replacing a cheaper watch gecko strap. This watch was the one that helped me appreciate how well brown straps go with blue watches.
Then this afternoon I decided to try to change some batteries on my wife's watches. So frustrating. Very hard to get snap-on casebacks off. One came off with a case knife, but 3 needed a jewellers screwdriver, and a lot of pressure. Fortunately, I had all the right batteries. Then I could only snap one case back on by hand, and I had to use a case press for the other three, I thought I had damaged one of the crystals, but after a very close inspection, it appeared there was an unremoved film on the front - so in the end a successful result.
Here's the blue watch anyway.
Today's Battery Changes
Re: Today's Battery Changes
The right tools make all the difference. Trying to do the job with improvisation usually turns out more expensive (damages) than investing in the correct tool, or going to a professional. No shame in admitting you are not equipped
I've got the tools, but not the knack and sufficient experience with them yet. Anyway these weren't expensive watches, so good practice.
I just can't move that screw in case back with a Jaxa wrench though. I can some. The watch guy must have screwed them in very tightly with his jig. And those jigs are rather more expensive than a Jaxa wrench.
I don't think I will be taking a mechanical movement apart any time soon though. Changing a battery is about the limit.
Mind you, I do have a quartz that needs a new movement so that would be a new movement, a hand lifter tool, and a hand setter tool, and swap the dial on to the new movement. I might try that.
Did it look like this? Best case tool I ever invested in. Of course this is overkill for most, but over the years it has paid for itself many times over.
There are tools and there are tools. If you can't move that case back then I would suggest you do not have the right tools. Of course, investing in the right tools may make no sense when you use them only occasionally.
@kip
Yes. That was the sort of thing the professional chap had. I saw some like this on eBay but wasn't completely sure it was the right tool, and it would be a lot to spend on the right tool, and even worse if it wasn't the right tool. It certainly turned the case back with no difficulty.
- 243 Views
Last post by the1bam
- 208 Views
- 36 Replies
- 1687 Views
Last post by exHowfener
- 637 Views
Last post by MiniMpi
