Watch strap for LE2009
I'm still considering changing the bracelet on my LE09 to a black strap. Is there anywhere else to purchase this style of strap as the le09 does not have lugs?
Also how exactly does the strap fit this watch?
- rcherryuk
Re: Watch strap for LE2009
You need to ask Wera for the strap bars, these have a threaded end which you remove, you then and pass it through the strap and the case and then replace the threaded end.
You can get leather or alligator straps from CW or get custom made straps from many sources, theres a great guy called Toshi who posts on TZ-UK, many of us have his straps, however if he's not made one for a C2 before you might need to send him the watch so he can ensure it fits perfectly.
Rob
Rob
Rob
Samuel Johnson
Samuel Johnson
Thanks for that. So if i order a strap from CW will it come with the strap bars or do i purchase these separately?
- Monkey
widge34 wrote:Thanks for that. So if i order a strap from CW will it come with the strap bars or do i purchase these separately?
I'd imagine they'd come 'with' as it's not a regular strap using regular spring pins!!
Monkey wrote:widge34 wrote:Thanks for that. So if i order a strap from CW will it come with the strap bars or do i purchase these separately?
Just contacted Chris, and yes, the strap comes with bars and fitting instructions.
So what type of tool would i need to remove the pins that hold the bracelet to the watch?
- rcherryuk
If you have them very fine pin or drift. If you have very steady hands you could try using a thin jewellers screwdriver. once you've pushed the bar out sufficiently from one side then use a pair of pliers to ease it out the rest of the way.
Be careful as once the pin is out the sleeve that it 'binds' in will drop out and disappear if you're not careful!
Rob
Rob
Rob
Samuel Johnson
Samuel Johnson
- Loddonite
I refer the honourable gentleman to my earlier answer http://www.christopherwardforum.com/vie ... =35&t=3784widge34 wrote:So what type of tool would i need to remove the pins that hold the bracelet to the watch?
Dom
Nothing's forgotten, nothing's ever forgotten.
Black leather strap now on. Fits the wrist better than the bracelet and watch is also lighter. Just need the strap to soften now.
No worries....it only takes a few days.widge34 wrote:Black leather strap now on. Fits the wrist better than the bracelet and watch is also lighter. Just need the strap to soften now.
- Newbie
I'm curious, if I wanted to get another Non-CW strap for the LE09, what type would I need to look for?
I'd love to find a black carbon fiber with white stitching, but just being able to browse some others would be nice.
- Loddonite
I am not aware of there being aftermarket notched straps that will specifically fit the C2 [anyone know if the IWC Ingenieur has the same measurements?]...combatcupcake wrote:I'm curious, if I wanted to get another Non-CW strap for the LE09, what type would I need to look for?
You need a 26mm strap with the central 14mm section cut out of it (or you could cut it out yourself ). The strap material would have to be thin enough not to foul on the case (the strap bars are quite close to the case) and if you were to do the cutting out you may leave a rough edge .
If you are not a leather crafter yourself you can commission a custom strap (at a price) from somewhere like this... http://www.abp-paris.com/ ... there is an online customised order form on the site. (I have no connection and have never used them myself - just the first custom strapmaker I clicked on while googling)
I have read good things about http://www.banda.com/ on another forum.
Dom
- rcherryuk
You could try here: http://www.toshi-straps.co.uk/ but you will need to get the screwbars from CW first as otherwise your new strap won't connect to the watch 'head'.
A good handmade strap that should outlast the watch will cost you in the region of £50-£60.
Rob
Rob
Rob
Samuel Johnson
Samuel Johnson
- Newbie
- Newbie
Another question:
how do you keep this
From turning into this
Is it just from sweat and I'd be better with a waterproof strap? Of course, cant really do that with the Lido.... welp.
