Backward LE Bracelet
- rcherryuk
Hi,
I had noticed, as had many others that the logo on the LE bracelet was upside down,well after comparing it to the bracelets on other watches I realised that the Logo isn't upside down, the whole bracelet is on backward!
So I popped the bracelet off,reversed it and voila! the logo is the right way round AND the bracelet fits better.
Maybe they were fitted in a hurry?
Rob
Rob
Rob
Samuel Johnson
Samuel Johnson
Re: Backward LE Bracelet
Seems it may have been a "Rookie" who didn't understand the proper way to install them.
That's quite ironic really. I bought my LE on leather, and ordered the bracelet separately.
It arrived today, and they actually come with instructions on how to fit the bracelet to the C2!
A newbie here, saying Hi
I like the look of the bracelet but it's hard to tell from the various pictures I've seen...
a) Does it have any micro adjustment around the clasp
b) How is link removal done? Are the links screwed or push-pins?
c) Can anyone pop theirs on a scale - what does the watch weigh complete with bracelet?
Nearly bought a C6 Kingfisher awhile back, but couldn't quite get past it being quartz and wasn't completely convinced of the dial colour & bezel.
This however, looks a beauty.
a) Sadly not
b) Pins have screw heads, although the jeweller who adjusted my bracelet did it as if they were push-pins No obvious harm done.
c) Not sure, sorry.
c) Not sure, sorry.
Out on the wiley, windy moors....
C2LE
S3SWS (the FPO's)
R20-DEC-SKK (ditto)
C6SOSI
C80GB1
C11-AUTO-BENZ-SKK
Member of the C80 Owners Club
C2LE
S3SWS (the FPO's)
R20-DEC-SKK (ditto)
C6SOSI
C80GB1
C11-AUTO-BENZ-SKK
- rcherryuk
The links are good old pins, I've resized mine,you can do it as well if you're not too 'fumble fingered'!langtoftlad wrote: b) How is link removal done? Are the links screwed or push-pins
See here for information on how to remove links, you can pick up a reasonable link removal tool for a fiver on the 'Bay'
http://www.pmwf.com/Watches/WatchSchool ... celets.htm
Also the bracelet is fastened to the watch case by sleeveed pins, If you want to fit a strap afterwards ask someone at CW to send you a set of 'screwbars' to fit the strap.
Rob
Rob
Samuel Johnson
Samuel Johnson
Hello, welcome!langtoftlad wrote:A newbie here, saying Hi
I've just thrown my C2LE and bracelet onto the kitchen scales, and although they're not renowned for accuracy, they are telling me that the combo weighs 175g.
There is no micro adjustment at the clasp, it's a butterfly arrangement, but the bracelet does have two half links, so you should be able to get a good fit.
The links for adjustment are push pins, even though one end is slotted to look like a screw.
Hope that helps, and you're right, it is a beauty!!
Ideal number of watches in your collection = current number of watches + 1...
Thanks all - I've got one of those gizmos, thanks Rob - it's always useful to "know" how to tackle a bracelet before starting rather than scratching about trying to unscrew pins or push out screws
I see the last few are on the main sales site - albeit without pictures and a fiver more - labeled as the C20 LE
Cheers
Cheers
- rcherryuk
They are split pins, so the pin is folder back on itself,leaving what looks like a screw head at one end and a little 'bump' at the other. They should only be pushed out from the non 'split' end.Tooks wrote:The links for adjustment are push pins, even though one end is slotted to look like a screw.
Most brcelets have a little arrow on them to indicate which way to push the pin out.
Rob
Rob
Samuel Johnson
Samuel Johnson
Er, yes, I know. I own one and have removed it, put it back on the right way round, and adjusted it!!rcherryuk wrote:They are split pins, so the pin is folder back on itself,leaving what looks like a screw head at one end and a little 'bump' at the other. They should only be pushed out from the non 'split' end.Tooks wrote:The links for adjustment are push pins, even though one end is slotted to look like a screw.
Rob
I know it isn't a screw, I just didn't want anybody trying to turn the 'screw end' with a jewellers screwdriver and wondering why they weren't getting very far.
Blimey, they're well hidden!! Prospective buyers are gonna have to work hard for theirs....langtoftlad wrote:I see the last few are on the main sales site - albeit without pictures and a fiver more - labeled as the C20 LE
C2LE
S3SWS (the FPO's)
R20-DEC-SKK (ditto)
C6SOSI
C80GB1
C11-AUTO-BENZ-SKK
C2LE
S3SWS (the FPO's)
R20-DEC-SKK (ditto)
C6SOSI
C80GB1
C11-AUTO-BENZ-SKK
Although the logo may now be the right way round. Isn't the words Christopher Ward on the bar underneath the Clasp upside down now?rcherryuk wrote:Hi,
Rob
- rcherryuk
Is should read correctly if you roll your wrist 'over'. The brand should be in line with your arm .widge34 wrote:Although the logo may now be the right way round. Isn't the words Christopher Ward on the bar underneath the Clasp upside down now?rcherryuk wrote:Hi,
Rob
Rob
Rob
Samuel Johnson
Samuel Johnson
Re:
Did you swap the bracelet over yourself? Was it easy enough to do?paw3001 wrote:Yes but those words aren't seen while wearmgbthe watch. However the logo is visible and as we in the West read left to right it needs to be swapped to look right.
I swapped mine and not only did it look better, the bracelet fit better and was easier to put on and take off.
- 13 Replies
- 480 Views
Last post by Noush
- 461 Views
Last post by SammyD
- 233 Views
Last post by scampbell61
- 380 Views
Last post by Matteocrossista
