Make your own "as-good-as-Rolex" bezel click spring
General watch information including stories of movement and brand development, service information and watch/movement evolution.
CW-watches: 24
Post by gaf1958 »
This is an excerpt from a Sydney watchmaker’s newsletter that I receive daily - it’s mostly about watches for sale, but sometimes include ‘how to’ tips, this was one that I thought worth posting here, as it’s a great DIY hack. He’s quite a sarcastic so and so, which you’ll undoubtedly pick up on from the first two paragraphs...
There's nothing more annoying than a broken click spring on a Rolex Submariner bezel, or losing one when you are cleaning your bezel. Getting a replacement from Rolex is impossible without taking the watch to a Service Centre. Have fun with that.
The Rolex click spring is conveniently made out of 0.35mm wire. A standard 0.4mm would not fit and 0.3mm is too weak. Yes, it looks like you have no choice but to take your Sub to Rolex. Luckily, you are a subscriber to this fine newsletter so here is a quick hack that will get you out of trouble.
A click spring is just a piece of nickel coated carbon steel wire with a very high yield strength. Something like a guitar string. And guess what? The B2 guitar string is exactly 0.35mm in diameter so this is what you can use to make your click spring.
A B2 guitar string is available from any guitar shop or on eBay for less than a dollar - enough to make 100 click springs.
Tools: Pin vice, wire cutters and a bit of a fine grain sand paper.
(1) Cut a length of B2 wire, approximately 20mm.
(2) Place it in a pin vice and deburr (polish) one end to get rid of the sharp clipping edge. Use fine grade sand paper. This is your end A.
(3) Clamp wire again with exactly 11mm sticking out.
(4) Bend 90 degrees. To bend the wire, simply push it with pin vice against solid surface.
(5) Clamp wire again, this time end A going inside vice.
(6) Clip to 2mm length. Polish the edge.
This completes cutting and polishing and you are ready for bending.
(7) First bend: clamp as per photo. Bend to angle around 35-40 degrees.
(8) Second bend: clamp per photo, 3mm of end A wire inside vice, bend 15-20 degrees.
Done!
Note: This quick DIY is provided for educational purposes as an opportunity to learn how to make a watch part and showcase your workmanship. We don't sell Rolex click springs but we will happily sell you a tool for you to make one.
CW-watches: 34
Re: Make your own "as-good-as-Rolex" bezel click spring
Fascinating Gary.
Is that all it is?
Love his final paragraph.......
Re: Make your own
An interesting DIY guide for anyone inclined to try and make one.
I would however go down what the writer views as the fun route of visiting a Rolex service centre, sit in reception and read a few brochures, whilst they fit a new click spring, whilst I wait. Probably be in and out in under half an hour. Simples.
The construction of the current six digit ceramic bezel models is a bit more complicated.
Re: Make your own
nbg wrote: Wed Feb 27, 2019 11:39 am Simples.
...to quote Theresa :lol:
Re: Make your own
Thegreyman wrote: Wed Feb 27, 2019 1:21 pm
Patrick I was trying to think of a response to your post that wouldn’t end up being deleted, for multiple infringements of the family friendly forum guidelines! :lol:
Nope can’t do it. :) So back on topic, if you were looking to pull off the bezel on your more modern Submariner, these pics may help.
Re: Make your own
^^^yes wouldn't want you to get in trouble, this emoji is useful :censored:
Just about to go and get the pliers to work on my SubC now :lol:
