Hi all - am having problems using the forums via the Tapatalk ios app. Any ideas what the problem is?
Tapatalk issues
Re: Tapatalk issues
Don't know what the issue is but I get it frequently too.
Solution is just to accept the 'ok', go 'back' and you will be asked if you want to save, delete or cancel your post(draft).
Just 'save' and OK. Then 'refresh' the thread and you'll find your post will be there.
Don't be tempted to post again; you'll end up with a double post.
Hope this helps.
Hope this helps.
- JAG
Re: Tapatalk issues
Are you trying to put emojis In the post ??
Sent from a iphone but not a APPLE FANBOY
My spelling & Grammar stinks i no you don't have to PM me to Explain !
Re: Tapatalk issues
This post was from Tapatalk without Emojis. Are they they issue at play?
- JAG
Re: Tapatalk issues
I've running tapatalk no issues unless I insert a emoji
- Ddavidsonmd
Tapatalk issues
I have the same issue due to emoji in my Tapatalk signature. Interestingly enough, if I post a photo in the post it works. Not sure why. This only happens in this forum as other forums i participate in are fine
Michael
[SEE-NO-EVIL MONKEY][HEAR-NO-EVIL MONKEY][SPEAK-NO-EVIL MONKEY]
Michael
__________________________
Michael
Michael
- JAG
Re: Tapatalk issues
I think iPhone emoji & android emoji are wrote in different coding so that's the emoji issue . I would say it's a coding error between tapatalk & php coding ?
- 670 Views
Last post by thomcat00
- 9 Replies
- 304 Views
- 1121 Views
