LE clasp material
- Hans
Re: LE clasp material
Sure, a IPK-clasp will look o.k. on the LE, but my problem is that we arranged 100 LE's and they should be identical! At least CW should have communicated it with me that they were planning on using different clasps!
100 % my oppinion.Hans wrote:Sure, a IPK-clasp will look o.k. on the LE, but my problem is that we arranged 100 LE's and they should be identical! At least CW should have communicated it with me that they were planning on using different clasps!
I don't complain about this point and I am not disappointed, but we should talk about.
Nico
Some news:
As expected, Chris wrote me a mail with the offer to send me a replacement clasp. I am very happy with this solution and my third CW watch.
Good job, Chris
Nico
Good job, Chris
Nico
- Senior Expert
I got the black clasp with mine too, and I think it suits the watch ans strap fine.
I still haven't heard back from Chris about my steel strap though! I emailed him about it last Tuesday!
With regards to there being 100 LE's that should all be identical, surely just by having a choice of 4 straps initially, that ensures that there will be a variety??????
Cheers,
Adam.
Caught the bug........
Adam.
- hantsman
- Senior Expert
Im guessing the rubber strap took off in a big way and he simply ran out, so he sent what he had in stock! Also we all know on here that we could mail him for a postive outcome!
Some news:
Today, the deployment strap arrived. A complete strap with steel clasp, for FREE!
Chris, you are great!
Nico
Nico
- David James Payne
Great news Nico - and now the job of fitting it!!
David
David
Joy to all watch lovers.
DJP
DJP
It took me only 1 minute! I had only to change the clasp. The strap has been fitted for the black clasp last year.David James Payne wrote:Great news Nico - and now the job of fitting it!!
David
Nico
- David James Payne
Ah that simple! I had forgotten that you already had a rubber strap fitted.
I had intended to fit a replacement blue Hirsh strap, which fitted the contours of the watch body - http://www.hirschag.com/23.1.html?model ... 5&pos=-350 - so I removed the existing rubber strap and tried to fit the new strap which I had purchased in anticipation!! It was a definite no go
Even took the watch and strap to my local watch shop where I had bought the new strap - they couldn't fit it either (so it wasn't me ) . Luckily they were good enough to give me a complete refund for the Hirsch strap.
Then I had to refit the rubber strap, and what a bug...r that was.
It took over 1/2hr of cursing and swearing (I will never get to heaven now ) before I finally fitted it - not a job that I would wish to repeat too often. Not too sure how many others have had problems with fitting straps, but I seem to recall other postings on the site expressing surprise at how difficult it was to fit straps.
Anyway I will be speaking to Chris to see whether he can recomend any replacement (waterproof) straps, or explain why it is so difficult to fit the Hirsch style strap, because a blue strap, to complement the blue of the LE dial would, IMO set the watch off better.
David
David
DJP
DJP
You are right, guys. Assembling the rubber strap to the LE case is very difficult!
First time fitting the strap, it took me about 30 minutes.
The problems are:
- the rubber strap is very thick. You have only a few place to use a "strap-changing"-tool! Solution: You have to push the pins from the top of the watch and jog them into the pin-holes of the case. Very difficult! Normally you can use the tool and press the pin-ends. It is not possible with the LE.
- the pin-hole in the strap has another axis than the pin-holes in the case. Even if the strap is located directly to the case, the pin cannot fit in the pin-holes of the case! Solution: You have to bow the pin a little bit.
Nico
The problems are:
Nico
- David James Payne
Yes Nico, you are absolutely right re your last point re the axis of the spring bar hole in the strap, relative to the watch case lugs - this is why the Hirsch strap wouldn't fit. Because of its construction the Hirsch strap has a plastic insert at the point where the strap meets the watch body, and the spring bar hole goes through this plastic insert. This means that there is no give in the strap end so does not allow any manouvering to try and align the spring bar with the holes in the watch lugs - so very frustrating and limiting in relation to trying different straps. . At least the CW rubber strap has some give which eventually allows mating to take place .
David
David
DJP
DJP
Now perhaps we know why some LE's didn't have the straps on? The assembly elfs gave up!
Yeah, they send me some extra springbars, that does not help even, it has to be something in the design of the clasp. So bending the springbar a bit would help?
For me the T3 IPK metal clasp is a real no no, my wife dislikes the shining of it. So the silicon strap is a must. A good advice would really help me out and start wearing the watch.
- 768 Views
Last post by DirkWatch
- 264 Views
Last post by iain
- 156 Views
- 204 Views
Last post by The Watcher CW
