New pictures of the Kingfisher Limited Edition
- Hans
The LE Kingfisher with blue superluminova, red-tipped second-hand, and Limited Edition 1000 ft / 300m printed on dial:
With leather strap (rubber or steel/IPK are also possible):
Printed on the back:
Re: New pictures of the Kingfisher Limited Edition
Any possibility of a lume shot?
- Hans
That will be difficult Joe, because these are the design-pictures... but close your eyes a bit, boost your imagination and picture the same image with everything very dark, and the indexes and hands a bit brighter then now
(actually, I think the lume in these designs is a bit exaggerated, so these are already kind of lume-shots)
Hey, I gave that a shot. When I did it, the Forum LE came with a free yellow KF too. Does this really work?Hans wrote:... but close your eyes a bit, boost your imagination and picture the same image with everything very dark, and the indexes and hands a bit brighter then now
- El Tiempo
I wasn't really attracted to the watch that much but it looks really appealing now. I also noticed it says 1000/300m. Did something change? The forum edition engraving on the back is also a nice touch.
Edit: What about the bezel dot? Will it be blue also?
- Hans
ET, 1000ft / 300m was also on the original LE design, nothing changed there.
The bezel dot: good question, I'll verify this with Chris.
- Hans
The dot will be white as shown in the last images. I talked about it with CW, and we tried it with blue but we agreed that it will look much better with white.El Tiempo wrote:I wasn't really attracted to the watch that much but it looks really appealing now. I also noticed it says 1000/300m. Did something change? The forum edition engraving on the back is also a nice touch.
The normal C6 Kingsfisher-Pro is 140g and since the LE is an automatic - what will the weight be?
- Hans
Probably a bit heavier, around 160-180g I assume, but I'll verify with CW!
Thanks for checking with CW. Also, is the deep sea blue dial face the same as the standard C6 Kingfisher Pro watch? I apologize if the answer exists somewhere in the forum
Hans, just to confirm because I think it looks cool in the picture, the square around the date aperture will be lumed?
- peterh
I think that we can now safely assume that Joe's mind has gone off the deep end.joerattz wrote:Hans, just to confirm because I think it looks cool in the picture, the square around the date aperture will be lumed?
- 12 Replies
- 1130 Views
Last post by dbailey
- 552 Views
- 31 Replies
- 1944 Views
Last post by albionphoto
