running fast
A limited Edition Kingfisher especially for forum-members
Sold out
baz003h
running fast
Post by baz003h »
My Kingfisher LE is running very fast do i need to send it back to get it adjusted because of the watch guarantee etc or can i go to a watch repairer
joerattz
Re: running fast
Post by joerattz »
How fast?
rcherryuk
Re: running fast
Post by rcherryuk »
baz003h wrote:My Kingfisher LE is running very fast do i need to send it back to get it adjusted because of the watch guarantee etc or can i go to a watch repairer
I had a problem with mine, sent it back and it was back within a fortnight,running fine with a new movement!
Rob
Rob
Samuel Johnson
seaclose
Re: running fast
Post by seaclose »
My LE is about 25 seconds a day fast against our radio controlled clock.
It doesn't really matter as I rarely wear it two days together but do you think I should get Chris to sort it?
CW-watches: 150
Re: running fast
seaclose wrote:My LE is about 25 seconds a day fast against our radio controlled clock.
I would suggest you wear it consistly over a week to 10 days and check the performance then before sending it back.
You will then have a track record to make a valid decision.
seaclose
Re: running fast
Post by seaclose »
Thanks Kip, I'll do that.
