I was looking at getting the 20mm Mesh Bracelet for the C9 Moonphase white dial I purchased in the new years sale, but it seems that Christopher Ward will only adjust the bracelet to 19cm - but my wrist (yes, I have straw arms) is only 16cm.
Which is strange as I wear a 43mm Trident bracelet after removing enough links to fit my wrist.
Is this due to how the Mesh bracelet is made, it's not possible to adjust smaller than 19cm?
16cm Wrist Size - Mesh Bracelet
Re: 16cm Wrist Size - Mesh Bracelet
Some Milanese mesh bracelets have a sliding clasp and are pretty well infinitely adjustable,
Others have a fixed length mesh section, but then have a few removable links and a normal butterfly clasp, and these can be awkward to adjust below a certain length. Maybe they come in S M L sizes. Do you have any images you can see?
The CW Milanese is sourced from Staib in Germany and is available in three sizes 130, 150 & 170 mm, each being adjustable by about 2cm using removable links. CW only offer the 170mm size I believe (hence your problem) but worth a word with customer services to see if they can get the smaller size. If not, you can source on ebay or probably elsewhere, the Staib model number is 2792. There is no special CW marking, they are identical.
I have one on my C1 Moonphase, it's a really nice bracelet and matches very well so I'd recommend.
Good luck
Good luck
- 18 Replies
- 959 Views
Last post by Mr Xv3
- 392 Views
- 10 Replies
- 389 Views
Last post by thomcat00
