Customs help please
- Newbie
Customs help please
This is the first time I've imported a watch injury the USA that's over $800. DHL says they need me information, as in they need the price breakdown of the watch parts. I paid $990 for the watch with discount, I have no idea what the breakdown would be. Any ideas on how to do that?
- village
- Location: any further South and my feet would be wet...
Re: Customs help please
I have to say I’ve never heard of that before. A breakdown of the parts? Sounds ridiculous.
If you can read this you are too close to your computer screen....
I'd be tempted to reply with a link to the watch you purchased (I'm guessing you bought it online) and confirm that you have bought a working and complete mechanical watch and ask them what other information they need.
- missF
- CW Forum Poet Laureate
Advice from forumites before has been to contact CW customer service. They provide this information to DPD, and are reliable at doing so. DPD don’t always pick up that info. Customer services will sort it out for you.
Edit : DHL
Edit : DHL
Watchaholic
‘Imprudently spendy’
Thomcat00
Watchaholic
Thomcat00
- Newbie
Apparently in the US movements, cases, and straps are taxed at different rates. The worksheet DHL sent me asks for the value of each component and a total value.
Getouttahere!dennisbible wrote: ↑Sun Sep 05, 2021 11:04 amApparently in the US movements, cases, and straps are taxed at different rates. The worksheet DHL sent me asks for the value of each component and a total value.
If your purchase was a new CW, MissF has given you the best advice possible
But honestly, different rates of taxation for the component parts of an assembled product smacks to be of "discouraging imports in favour of the home-grown product". I wonder if Donald wore a shinola?
Missf has indeed given you the best advice. This will usually fix the issue.
I have stated this many times.... When CW ships watches to the USA they send DHL a spreadsheet with all the information including the Waybill number for items picked up on any given day. Much depends on the agent viewing the package to simply look up the email by manufacturer and then find the Waybill number. In most cases they do and get all the required information. If they can't find it for any reason, they are supposed to contact CW for it. CW informs me that when they resend the email they usually spot it then.
If they don't contact CW they will likely send you a worksheet like the one below that requires you to fill out and return along with a copy of your CW invoice as well as waybill from DHL.
- Newbie
DHL sent me the worksheet.Kip wrote: ↑Sun Sep 05, 2021 11:56 amMissf has indeed given you the best advice. This will usually fix the issue.
- MichaelMD
Same thing happened with me. You just fill out the sheet and break it down with a percentage movement vs case vs bracelet/strap. The movement is the highest at like 60-70% then case, then strap. These three numbers added up would be the total cost you paid. PM me if you need more help.dennisbible wrote:DHL sent me the worksheet.Kip wrote: ↑Sun Sep 05, 2021 11:56 amMissf has indeed given you the best advice. This will usually fix the issue.
Sent from my Galaxy S20 using Tapatalk
- Newbie
Thank you guys. I submitted the form based on your advice. I'll let you know how it goes.
- Newbie
I wanted to update and get some input. Delivery was scheduled for tomorrow and that clearly isn't gong to happen. I submitted the customs form two days ago and when I track the order it says delayed not by carrier. Is this typical? How long does this usually take?
- CW-watches: 15
Now your watch is likely caught in the Labor Day delay. Shouldn’t take much longer. I’ve had holidays trap my items with Customs for up to 5 days. Annoying but not the end of the world.dennisbible wrote: ↑Wed Sep 08, 2021 1:59 am I wanted to update and get some input. Delivery was scheduled for tomorrow and that clearly isn't gong to happen. I submitted the customs form two days ago and when I track the order it says delayed not by carrier. Is this typical? How long does this usually take?
with Kung Fu grip, and life-like hair
- MichaelMD
Did they acknowledge receipt of the customs form you sent in? As long as they did that you are fine. Just be a day or so delay. Mine took a couple days longer than they originally said. Then DHL claimed they couldn't find my address or that it wasn't a valid address. Took several calls to DHL where they actually looked my address up and sure enough there it was right there on GoogleMaps. They called the driver and I guess explained that my address does in fact exist. The second attempt at delivery wound up getting it to me.dennisbible wrote: ↑Wed Sep 08, 2021 1:59 am I wanted to update and get some input. Delivery was scheduled for tomorrow and that clearly isn't gong to happen. I submitted the customs form two days ago and when I track the order it says delayed not by carrier. Is this typical? How long does this usually take?
- 279 Views
Last post by Southfrance
