Repair Process For C20 Lido
Unfortunately the day/date bezel on my C20 Lido has come adrift and is lodged on top of the 12 marker.
I've sent CW support a request for an indication of repair costs along with a photograph of the fault, however they've replied stating that their technician needs to inspect the watch before they can give me an estimate.
Is this the usual process for what is an obvious fault?
C20 Lido 0694 by Ranger, on Flickr
Gettin' A Whole Lot Older Every Day...
- EcosseOz
Re: Repair Process For C20 Lido
How do you know/determine its an obvious fault?
May very well be related to the way the watch has been treated by its owner, so IMHO its not unreasonable for CWL to make that decision on providing a quote.
The CW Collection: Now well used C6IPSI (#2)
C4IP4 (#1331)
C6 Forum LE (#64) -Sold to Tikkathree
C6SWS (#761)
Non-CW: A Breitling, 3x Omega, 1xMido, that now (13y) more ancient Raymond Weil and a Dead Seiko I can't part with (32yrs+)
C4IP4 (#1331)
C6SWS (#761)
I have no personal experience with returning watches to CW for repair, so take my comment with a grain of salt perhaps.Ranger wrote: ↑Tue Jun 15, 2021 12:42 pm Unfortunately the day/date bezel on my C20 Lido has come adrift and is lodged on top of the 12 marker.
From what I’ve read on many occasions on this thread, it sounds fairly common for CW to say they can’t give an estimate of cost until the watch is in their possession, even for servicing.
While the fault may be painfully obvious from the photo, the cause and the fix may not be, hence the need to send it in first. And there may be other issues related to the displaced bezel not readily obvious.
Thanks for your thoughts, I guess I can understand them being cautious, I just thought they might be willing to give a ballpark figure before I go to the bother of sending it off.jkbarnes wrote: ↑Tue Jun 15, 2021 1:42 pm
And as a vaguely related aside, am I the only one who always things of Lido Shuffle by Boz Skaggs every time I see a the C2/C20 Lido mentioned in a thread?
I believe Steve (@Thermexman) had s similar issue with his wife's CW Charlotte Deco, with the surround to the small seconds sub-dial coming adrift (or something similar).
Maybe he will be able to enlighten you.
Thanks, I'll give him a shout.Bahnstormer_vRS wrote: ↑Tue Jun 15, 2021 2:48 pm I believe Steve (@Thermexman) had s similar issue with his wife's CW Charlotte Deco, with the surround to the small seconds sub-dial coming adrift (or something similar).
Unfortunately they won't even give a quote for something as simple as a bezel replacement without having the watch in their hands. By quote, I mean they won't even say "if the bezel just needs removed and replaced the cost will be £xxx". I have to admit that I think this is rather stupid and it has made me refrain from a repair.Ranger wrote: ↑Tue Jun 15, 2021 2:17 pmThanks for your thoughts, I guess I can understand them being cautious, I just thought they might be willing to give a ballpark figure before I go to the bother of sending it off.jkbarnes wrote: ↑Tue Jun 15, 2021 1:42 pm
I didn't see how old the watch was or if there are warranty implications but for that I'd be inclined to find a local watch maker to open it up and glue(?) It back on.
For a watch that's well past its warranty, I'd be finding a local watch specialist and asking them for a quote instead of CW.
Just my 10p's worth.
I don't think the day date window looks bad without the surround. I imagine it would be easy to remove the movement and just take the surround out without bothering to reattach it. Any watchmaker could do that. You might even have a go yourself, although you would need some equipment.
Ref to Guys post: this happened to my mums, I just removed the ring, she was more than happy, that’s what I would do, as mentioned before looks ok without it
- Thermexman
When my Wife’s watch did this, I sent it back and they fixed it for free. It then became detached a second time and so I glued it back on myself. A steady hand is required but it’s stayed in place ever since.
I'm bearing generous now but presumably there's scope for "oh and while we had your watch we noticed that XXXXXXXXXXX so the total estimate will be £ZZZZZ"? But from recent postings here I suspect you'd have to ask for a full inspection. I think I'd state as bleedin' obvious that I'd want them to ensure that no other dial furniture is about to detach itself.Bungle-ator wrote: ↑Tue Jun 15, 2021 3:50 pmUnfortunately they won't even give a quote for something as simple as a bezel replacement without having the watch in their hands. By quote, I mean they won't even say "if the bezel just needs removed and replaced the cost will be £xxx". I have to admit that I think this is rather stupid and it has made me refrain from a repair.Ranger wrote: ↑Tue Jun 15, 2021 2:17 pmThanks for your thoughts, I guess I can understand them being cautious, I just thought they might be willing to give a ballpark figure before I go to the bother of sending it off.jkbarnes wrote: ↑Tue Jun 15, 2021 1:42 pm
I'm sure I've seen Soviet era watches with "ring hands" as the major part of the design.Thermexman wrote: ↑Thu Jun 24, 2021 2:09 pm When my Wife’s watch did this, I sent it back and they fixed it for free. It then became detached a second time and so I glued it back on myself. A steady hand is required but it’s stayed in place ever since.
- jmarchitect
I think it looks better without the surround and I suspect an independent could whip the back off, remove the movement and remove the detached surround with no problems. I wouldn’t want that piece of metal flying around the dial though, so how likely is it the independent could repair damage to the dial or hands caused whilst the watch is in transit?
- 241 Views
Last post by gannet
- 460 Views
Last post by thomcat00
- 189 Views
Last post by jkbarnes
- 59 Replies
- 1648 Views
Last post by exHowfener
