Battery replacement? Ubi, Scooby?
Thee battery on my C70 Ascari COSC died a few days ago. Normally it would be off to some repair place in Norwich, but they're closed. CW service, likewise closed.
I don't really want to leave a dead battery in a nice watch for long, And I don't do case back removals and battery jobs.
Any suggestions, folks?
CW-watches: 24
Re: Battery replacement? Ubi, Scooby?
https://davidcarpenterwatches.com/
I use them for all my 'other brands' batteries and service. Authorised repairers for Omega, TAG and others.
About £30 for a Quartz battery with pressure test, which is similar to CW price. Quick turnaround usually too.
C8 Reg LE| C8 M2.04 LE| C8 Al Deere| C9 FLE| C9 Me109 SPC LE| C11 Mak Navy| C40 x2
C60 FLEx2| C60 Bronze-316L| C60 Apex-Elite P'type-AbyssSH21-Chrono
Richard D
Post by Richard D »
Are there any watchmakers working from home near to you that might be able to help?
welshlad
Post by welshlad »
Amor Vincit Omnia wrote:
Mon Mar 01, 2021 9:10 pm
Spookily, when I went to wear my C70 Ascari COSC today I also found the battery had died. I ordered a replacement one on Amazon, due on the weekend, and am planning to change it myself...if I stay brave enough! The watch won't get a pressure test going down this route, but that's not really a practical issue as it never goes near water.
However, if another good option emerges on this thread in the meantime then I'm happy to change my plans. :)
CWL C3 Mk1 | C60 Mk2 CWE | C60 Mk3 Ombre | C65 SC | C65 SH21 | C70 x4 | C8 | C8PR | C15
Citizen Promaster Vratislavia S6 Luch 1Hand
I just took a look at Michlmayr's in Norwich and will call or message them tomorrow.
Thanks for the ideas, chaps.
CW-watches: 146
Hey guys....if you are changing the battery yourself, cover the case back gasket with a thin coat of a non petroleum based grease. If will help to insure a better seal.
Bident
Post by Bident »
Kip wrote:
Mon Mar 01, 2021 11:55 pm
I use a silicone grease for the gasket. You can buy a type that comes in a circular container. Pop the gasket inside, screw the lid down gently, unscrew and the gasket will be sufficiently lubricated. Also handy for thicker spring bars in tight strap holes.
Sounds like AVO will not be doing this in any event. Steve, if you have any watch enthusiast friends nearby, perhaps they might have the experience and willingness to do this for you? If I were in your neck of the woods I would be happy to help you out. Alas, shipping costs and shipping times alone would make this a suboptimal solution for you (but happy to do this if you do want to pursue :thumbup:) .
Paul Drawmer
Post by Paul Drawmer »
I have been doing my family's watch batteries for the last couple of years.
You won't believe just how tiny some of the battery clip retaining screws are! Get some proper screwdrivers, and tweezers. And a magnifier that you wear, pref with a built in light.
It isn't difficult, just requires care and patience.
I like to buy Renata batteries.
rkovars
Post by rkovars »
Bident wrote:
Tue Mar 02, 2021 12:54 am
Here is an example from Esslinger.
In Review:
Post by Viognier »
Paul Drawmer wrote:
Tue Mar 02, 2021 8:46 am
Echo Paul's thoughts....ONLY use Renata batteries in our family's quartz watches!
Steve happy to offer up a Canadian option for the change if all else falls through
Absolutely agree :thumbup:
You must have the right tools and a magnifier/light - I have one of these https://www.argos.co.uk/product/9063134
The light at the end of the tunnel has been switched off due to budget cuts!
All the helpful suggestions are appreciated. The original question, however, was not how to replace a battery but where to get one done during lockdown!
StrappedUp
Post by StrappedUp »
Also, I'd recommend anyone changing their own batteries to wear an anti-static wrist strap or similar protection.
Don't want to be zapping your lovely watches! Even if it doesn't kill your movement, it can significantly reduce the life of it.
edit - Sorry Steve, I know my post is useless in answer to your original question, but thought it may be important for those that do their own.
StrappedUp wrote:
Tue Mar 02, 2021 4:21 pm
Maybe a different thread then, Ryan?
exHowfener
Post by exHowfener »
If I'm paying someone else to fit a battery, I find Timpson are quite good. The 'lifetime battery' option is useful. You can check on their website where is open.
