I am just amazed to hear that indices are placed by hand and then lumed in situ
+1 on that, surely this is done by machine rather than human?
On the returns, while trying a watch on should be expected, I don't think that anyone helps their case that the watch is "unworn" when they post wrist shots. But that aside, I don't think this is a matter for the 60:60 warranty - replacement rather than repair should be the way forward as this seem to be faulty.
exHowfener wrote: ↑Wed Mar 03, 2021 2:19 pm
I quoted it directly from Loupe magazine.
I found it surprising when I first read it and thought immediately that it may result in some wonky dials and discussions of perceived tolerance! To their credit the fact it has taken so long for one to slip through is impressive!
tzerenc wrote: ↑Wed Mar 03, 2021 12:58 am
I'll update you guys on the return process as it unfolds.
What options did the form provide? Have asked for refund or a replacement? I hope that they do not set off on a path to fix it instead which could leave you waiting a while!
Maybe it might be a good idea to add a clear note on the form as to what you expect to happen if it is not just a simple refund or quick replacement, or give them a call/message then quote that on the return too.
On the return form, I had the options: refund, exchange, repair, and service. I chose to exchange.
I also added a note in the return form writing: "The 3 o'clock marker is slightly crooked while the 9 o'clock marker is extremely crooked and highly noticeable. I would not like a refund, but rather a new replacement of the same model in the same color."
I hope that makes it clear enough to them that I want a replacement, not a repair.
Last edited by Bahnstormer_vRS on Thu Mar 04, 2021 3:20 pm, edited 1 time in total.
Reason:Attached photo 'Placed in Line' - https://www.christopherwardforum.com/viewtopic.php?f=4&t=55242
Like most guys, I've always liked watches. I can always check the time on my phone, but having a watch is so much better.
tzerenc wrote: ↑Thu Mar 04, 2021 2:47 pm
Sounds good, hope you receive a speedy outcome and the saphire is back on your wrist soon
