Opinions on Staib mesh bracelet?
MichaelMD
Post by MichaelMD »
Two days into Wordglow ownership and I'm already considering adding the mesh bracelet. I'm not a fan of leather straps in the heat of the summer. It looks like the one that CW sells is the Staib Polished Mesh Bracelet. Does anyone own one these? Curious to get some opinions and a wrist shot or two if possible. CW only sells the 150 mm version so I would need to buy the 170 mm from another vendor. I do like that this particular mesh bracelet has removable links for sizing. Never owned a mesh and wondering are they too flashy looking, too "blingy" ???
Re: Opinions on Staib mesh bracelet?
I have one. Good quality, although I don’t often wear it, so don’t have any pics.
I will ferret it out, stick it on a watch and put up a couple of pics for you later this afternoon, so you can checkout the bling factor.
MichaelMD
Post by MichaelMD »
nbg wrote:
Thu Feb 11, 2021 3:00 pm
That would be great, thanks Neil. Can I ask why you don't often wear it?
CW-watches: 24
Do you really need the 170mm?
If you get the 150mm from CW, factor in approx 50mm for the watch and you're at 200mm = 20cm - 7 7/8" wrist.
As to a mesh bracelet in itself, the Worldglow is a Sports/Dress watch, I'd say perfect. Its more flexible than a standard bracelet and none of those gaps to get wrist hairs trapped in.
I had similar thoughts on the quasi-mesh bracelet for my Visitor Duneshore but bought it anyway. Now that I have it, I'm glad I got it.
C8 Reg LE| C8 M2.04 LE| C8 Al Deere| C9 FLE| C9 Me109 SPC LE| C11 Mak Navy| C40 x2
C60 FLEx2| C60 Bronze-316L| C60 Apex-Elite P'type-AbyssSH21-Chrono
JasperCat
Post by JasperCat »
I have the CW (Staib) 20mm mesh bracelet for my C5 MMVX FLE. I don't keep it on all the time, as I prefer leather most of the time on this as a dress watch, but when I do it's very comfortable and does add a little "bling" to the watch :D
It's also very easy to resize by removing/adding link sections around the clasp. I think mine was one of the earlier versions which was actually 170mm and for reference, I've had to remove one link on my 7.5" wrist... however the C5 is a possibly a slightly smaller watch, so the Worldglow might not need the additional length :?
FWIW, If I had a Worldglow or Moonglow, I'd probably put it on the mesh too :thumbup:
Here's a few photos, hope they help... two on the mesh and one a the black (croc pattern) Bader deployant strap for reference...
C60 Elite GMT 1000, C65 SH21 LE, C65 Cranwell, C8 Power Reserve, C65 Super Compressor,
C65 Blue Bronze Prototype, C65 Black Gold LE, C65 316L LE, C60 Trident Pro 600 MkII, C5 MMXV FLE,
C65 AM 2 VEV SE
MichaelMD
Post by MichaelMD »
Thu Feb 11, 2021 3:12 pm
Hmmm you might be right on the 150. I measured the outer length of the leather strap as it is set now at 170mm. But that number is inflated due to the end of the strap under the deployant. Interesting, when I measure the circumference of my wrist I'm getting 190 mm. Lug hole to lug hole is around 47 mm on this watch so I think you're right that 150 might do it.
MichaelMD
Post by MichaelMD »
JasperCat wrote:
Thu Feb 11, 2021 3:22 pm
That looks really sharp, thanks for posting. :clap:
JasperCat
Post by JasperCat »
MichaelMD wrote:
Thu Feb 11, 2021 3:43 pm
No worries, you're welcome :D
Lovely watch that Worldglow :clap:
C65 AM 2 VEV SE
MichaelMD wrote:
Thu Feb 11, 2021 3:09 pm
Hi Michael, I have just had a quick look, but can’t lay my hands on it.
The watch that initially bought it for was the C5 MMXV FLE - the same watch that JasperCat has it on in the pics. I have also occasionally worn it on a Speedmaster.
Thinking about it, the reason that I haven’t worn it more is that in my view it isn’t as flexible as say a jubilee or oyster style bracelet. It certainly doesn’t drape around the wrist as well as a jubilee or oyster. Some styles of mesh may well do, but this particular style of Staib doesn’t.
Whether that is an issue probably depends on wrist shape and size.
JasperCat
Post by JasperCat »
These Staib bracelets are also superb quality, very thick but comfortable... the only other mesh I have is the Milanese Loop for my Apple Watch and whilst that's comfortably, it's much thinner and feels slightly less "premium".
Remember you will need a strap changing tool for this, as it's not quick release like the straps and bracelets... it is very easy to change though with the right tool (I have a Bergeon) :thumbup:
C65 AM 2 VEV SE
JasperCat
Post by JasperCat »
nbg wrote:
Thu Feb 11, 2021 3:49 pm
That's a valid point, this Staib mesh doesn't drape, it basically goes around your wrist like a solid bracelet would do. The Apple mesh does indeed drape, as it's thinner.
It is however comfortable when sized correctly and feels super dressy/blingy :thumbup:
C65 AM 2 VEV SE
Yes. Without fitted end links its much easier to remove a bracelet. Probably easier than with a leather strap. as with the leather you have to force the tool between the leather and the lug, With a bracelet, you will have a visible access section.
missF
CW Forum Poet Laureate
Post by missF »
I think mesh looks really classy. Slightly retro, great for travelling watches. And definitely not as blingy as PCLs :thumbup:
'The only reason for time is so that everything doesn't happen at once'........Albert Einstein
MichaelMD
Post by MichaelMD »
Never thought about that but I can picture what you are saying. It doesn't follow the specific contour of the wrist. So it might work best on a rounder wrist vs a flatter one. My wrist is larger but flatter too. This is why bigger watches like the Worldglow work so well for me. Lot of real estate on the top of my wrist.
Maybe I look for a place to order over here in the States with a free return policy so I can actually touch/feel one before being stuck with it.
alanrolfe01
CW-watches: 19
Post by alanrolfe01 »
I had a similar issue with the Staib on the C3 GT recently. In error I didn't get it resized at CW. The 160mm length arrived although size options to 250mm are offered CW can only size up to 190mm. I'm waiting for an order of the additional links I need. It appears that Staib offer a few length options of mesh and then limit the range of links needed to cover a limited size range.
