Returns advice
Geefiasco
CW-watches: 15
Returns advice
Post by Geefiasco »
Hi, I’m about to return my 42mm C60 Trident Pro 600 for a 40mm version.
I just wanted advice on what would be more efficient before I fill out the returns form.
My initial order was:
- 42mm Trident (bracelet resize)
- 22mm Hybrid strap
- 22mm Rubber strap
What want in exchange:
- 40mm Trident (bracelet resize)
- 20mm Hybrid strap
- 20mm Rubber strap
Is this possible to do this all in one return form? As I presumed I’d have to fill out a separate form for each item.
What would you guys advise me to do? As I wanted the bracelet resized on the 40mm version too.
Many thanks.
The highest human act is to inspire.
tikkathree
Re: Returns advice
Post by tikkathree »
I'm not an expert but I think you can and my suggestion is that you try it and if it's a problem CW customer service will be in touch. The online form for returns requires your order number and the stock code (SKS?) for each item being returned. I think there's probably space to type in three SKS codes. There's also a free text box and you could overflow into that if needs be?
Hope this helps.
Geefiasco
CW-watches: 15
Re: Returns advice
Post by Geefiasco »
Many thanks. I’ll give it a go.
